What are the pros and cons of an equal length exhaust manifold?
Umm...the only thing that fires together for cylinders #1 and #4 is the spark. But we have a waste spark system where coil 1 will fire when it's needed and coil 2 will fire when it's needed. This works out fine because when #1 is on it's compression stroke #4 is on it's exhaust stroke so firing the #4 spark at the same time won't do nothing. There's no gas to burn.dyezak said:Well cyl #1 and #4 fire together, so their exhaust puleses match.
WhoTF are you talking about?! You seem a little confused on this, at least make sure you get the names right.NosLaser said:Bill, you are doing it again...
Bill...you are striking out dude. Do you really work on people's cars?
LOL! Umm, the pistons may be in time in your example but they most certainly DO NOT FIRE **on compression** AT THE SAME TIME, the valves have some say so there...ever look at your cams really close?!NosLaser said:Let me ask you a simple question...have you ever had the head off the car? Which two pistons do you see at bottom dead center, and which two are at top dead center? Cylinders 1 and 4 are in time, and 2 and 3 are in time. Cylinder's number 1 and 4 FIRE AT THE SAME TIME, and 2 and 3 FIRE AT THE SAME TIME (for nit-pickers, they are VERY slightly off, but so slightly it would be hard to measure with even measuring tools; it's determined by wire length, resistance, etc. but for arguments sake, they fire at the same time).
