My 1g eclipse GST (100% stock) idles with a strange lope almost like its cammed, but runs pretty good, still has decent performance, feels like a 15 second car, its only other issue is it takes forever to start when its really cold out. Its got 112k on the odometer, after throwing numerous parts at it without being able to cure the lopey idle i did a compression test. These are my results
#4 - 94 psi
#3 - 96 psi
#2 - 55 psi(went up to 85 psi when i added a dribble of oil into the cylinder)
#1 - 96 psi
I read I am supposed to have 180 psi on all cylinders... I'm thinking the compression gauge isnt reading accurately?( it was a cheap rental from autozone) I'm thinking if i had half the compression i needed on every cylinder the car wouldn't run. I guess I need new rings on piston 2 either way because it wouldnt have jumped up like that without adding the oil. Any thoughts?
#4 - 94 psi
#3 - 96 psi
#1 - 96 psi
