For those with notchiness or grinding while shifting....(kinda long)
7.7K views 32 replies 21 participants last post by  4G63tal
I wanted to write this little piece because I had a fellow from the Digest take the time out to help me with my crappy shifting DSM.
Starting with a little history, i bought my 90 Laser with 59k in Oct. 99. Car shifted a little notchy, but not bad i thought. Then in May 2000, the car was shifting really notchy and the clutch needed replacing. After the new ACT 2600 was in, the notchiness was still there and the clutch engaged about 1/2" from the floor. A season of 1/4 mi. racing didn't help the cause any either. I put in the Symborski shift kit. Solidified the shifting, but still notchy as hell going from 1st to 2nd. Oct. 2000, lost the shift fork and said hell with it. Rebuilt the tranny. Still notchy as shit. Put BG Synchroshift, no help. Finally I spent a few hours researching the Digest and emailing people with the same problem.
Any of you, especially 1G's, that have notchy shifting, grinding into 2nd (this could be worn synchros), or VERY low clutch pedal engagement (i'm talking 1" or less), CHECK THE CLUTCH PEDAL ASSEMBLY. One minor adjustment and all the efforts you put into the car to make it shift good will be realized.
Here is a brief description of what you are looking for: get on your back and look under the dash. Find the clutch. Follow the pedal back until you see it connect with a long rod that goes towards the center of teh car. Attached to that rod is a linkage that activates the pushrod on the clutch master cylinder. The linkage is held on by a pin (dowel). The hole this pin is in gets worn out over time, especially with aftermarket clutch. You push the clutch in, but the pedal travels a little before the pushrod on the master cyl. is activated. Therefore, your clutch doesn't fully engage/disengage. Mine was so bad, I couldn't get the car into gear. I would come to a stop, push the clutch through the floor and still roll. I would have to put in neutral, then rev the motor to get the tranny to match up with the engine speed, then try to slip into 2nd.
Now for the FIX!!! Attached to the linkage is the pushrod that activates the master cylinder. You can screw it out to make the pushrod activate sooner. Just turn the linkage counterclockwise. Best to unbolt the master cylinder in the engine bay first. Then screw the linkage out as far as safely possible without risk of falling out of threads or putting a load on the master cylinder.
If anyone needs any help, advice, or pics of what needs to be done, feel free to email me. I am writing this, cuz I know that a lot of you 1G DSM'ers experience this and don't know how to fix it. Here is the answer. There are other answers too, but this is the quickest and cheapest. It's FREE!!!
Thanks for the space,
Mike
hey Mike, i'm writing you an email. You are the king!!!! THANK YOU.
I too had this problem. Turning it helped... but only for a while. While you're down there check for black fluid leaking from the master cylinder... look inside the firewall just below where it come through. There's a good chance (especially with an upgraded clutch) that the master cylinder has had it and is leaking. This was my problem. If it's leaking swap in a new one or rebuild it. When the master cylinder dies it will result in less and less clutch disengagement and so more shifting problems. So if raising the clutch pedal engagement point doesn't help or helps only for a while check this.
Yeah, I had the same problem...Unscrewed the rod, and it helped for a bit. But slowly the clutch engagement was bad again. Unscrewed the rod all the friggin way out, and helped a bit again. Only a temp fix.
From what I understand, from reading digests,etc - the clutch assembly has a crappy connection to another rod, and where they connect gets worn out, especially with harder clutches. Some people welded this together again, others replaced it. I guess if you let off your clutch, and you can still pull it forward (like me) you have the worn connection I am talkin bout.
Hey thanx Mike, at least now I look somewhere else not only the tranny to find a reason for shift-grinds, Few days ago I've noticed that even sittin' at idle with the clutch engaged I could gear a deep "thump" sound while going into 1st gear, then I've revved the engine (cluth still engaged) and selected 1st again, this time it grinded :(
I guess my car is definetelly not dis-engaging the clutch completelly :(
I'll try your idea soon, I'll let you know if it worked!
Thanx for posting that!!!
Yeah I went through the same terror, when I recenlty converted my car from an automatic to a 5-spd.
I could not get the bastard into 1st without a heavy grind. I thought the trans was done for.
I even had the rod turned all the way out, and everything.
Some other things to check
Another thing to check is the nut at the end of the rod that runs from the pedal to the clutch level. If the nut is loose, when you push in the pedal, the level has play before it actualls starts to push in the master cylinder. Pull the pedal back, and tighten that nut. Hard to access, 14 mm.
Another thing that really helped me was bleeding the master cylinder. YOu do the same thing you do as at the clutch slave, but you do it at the master. It helped quite a bit. :)
All else was covered.
Thanks for all the info. everyone. Just a quick question to whoever might know: Since I bought my '92 AWD Laser 2 years ago with 66,000 miles, I can never get the car into 1st without grinding unless I come to a complete stop, then I have no problem. Also, now when I shift into second, if I don't wait for a 2000 RPM fall after depressing the clutch, the transmission will grind. I can still shift at a high RPM (like 4000), as long as I wait after depressing the clutch at 6000 RPM. Do you think this is b/c of this clutch linkage problem, or my syncros or clutch?
That pin is called a cleaves pin. What the problem is that your only working on the adjustment ( BTW no need to unbolt the clutch master to adjust it ) and like Quad said it will only last till it wears out that pin some more. the only REAL fix is to fix/replace the clutch pedal assembly. the 2G doesn't suffer as much with this prob as the clutch master is on the left or right above the pedal where on the 1G is it above the gas pedal.
But keep spreading the good word but be aware that what you have said is only a temp answer to a problem with most 1G's
A MUCH quicker way to see if you pin is warn out, press on the clutch and then after it returns put your foot ( or hand ) under the pedal and lift it up. If it moves up then guess what??? that is the amount of play in the pin!! :D all in all most can live with the adjustment for a long time but some times it so bad that it needs to be replaced like the one on my AWD TSI with 197K on it
Bill Marino
Hole Shot Performance
I agree with Quadcylla in that this is basically a TEMPORARY fix. I also have another temporary fix for when that one runs out of pedal travel. The same guy that helped me actually welded a nut onto the linkage to provide him even more travel for the pushrod. It does work, but eventually the cleaves pin will round out the hole so bad that you need to replace the entire clutch pedal assembly. Parts are about $100 I believe. It's the 6 odd hours or so that it would take to remove the entire steering column and pedal assembly to replace it that's gonna hurt!!!
If anyone wants pics of how and where to weld the nut to get even more travel out of that linkage, let me know.
Mike
I feel your pain, I've had to take out my pedal assembly 3 times, and replaced the pedal assembly parts twice, I also have an extra nut welded on for a huge range of adjustment. I have the art mastered and can remove and install the assembly in about 2 hours :) My tranny is still a bit notchy but I can shift fairly quickly, One thing I've noticed is with more power my shifting is slower (harder to do) I don't really understand how power would affect the speed of the shift other than the innertial momentum of the internal tranny parts is higher with quicker acceleration.
Mike "V8Killer"
fastest stock turbo DSM in Iowa
I'm curiuos how long does this temp. fix last? I have a fwd 93 talon tsi and it grinds like hell going into 3rd gear, will this temp fix help this problem? I'd hate to do this fix if it's only going to last a few months, now a few years thats ok cause I'll probally have to replace the pedal assem.
While thinking about doing this temp. fix. Please do not overlook the age of your clutch when troubleshooting your problem. You may just be prolonging the inevitable and ruin your tranny. And who wants to spend the time and money fixing that on top of the pedal assembly
My clucth is pretty new it only has about 1000 miles put on it, the grinding problem started before the clucth was replaced, now I know the sincroes in third are getting worn out, but will this temp fix help me?
It dosent grind in any other gear but third, I would really like to get rid of this problem without having to change the sincros due to money right now and for awile. I just whant to make the tranny last tell I get some money to rebuild it with better parts, if you have any ideas please help me I'm desprate man! This grinding is driving me crazy, and I cant understand why it shifts great in any other gear but third. HELP!!!!!!!
Had the same problems. The only solution I found was replacing the whole assembly... I did the tweaking, adjusting the master cylinder, REPLACED all hydraulics and this was the best fix... of course, since I drove it like that for a while, my synchros are bad... so don't let it go TOO long!
Easier Fix than Pedal Assembly
I know its been over a year and a half since the last post but I have some more info for this fix.
It's not necessary to remove or replace the entire pedal assembly. Instead the part that wears is the "clutch lever" and costs about $15-20. It can be unbolted and swapped in a matter of 1-2 hours.
Here's a link to a prior post of mine:
http://www.dsmtalk.com/forums/showthread.php?s=&postid=520598#post520598
exactly what is wrong with mine as well.
i just replaced the clutch (had a shop do it for me) now have a 2600 act.
my pedal was adjusted by my friend who turned some rod thing, must be what your talking about.
and it is starting again to get very hard to shift into gears and never goes in smoothly to any of them and the pedal is on the floor :(
I'm going to try to turn that again to adjust it, i noticed one time i let it go to long, and then my cruise control stopped working, and i had to actually pull the pedal up with my foot.
does anyone have a picture of where this rod is that i have to turn?
The threaded rod adjuster you're talking about is on the master clutch cylinder. Oddly enough its located above the throttle and not the clutch pedal. Look at the clutch pedal and follow the black rod that travels toward the passenger side. Connected to that is the clutch lever (THAT is probably the problem). Connected to that lever is the rod which pushes the master cylinder sticking out of the fire wall.
Adjusting that rod will only buy you some time, and it can preload the clutch which is a very bad thing. If you adjusted the rod to the last threads and the clutch pedal doesn't return all the way unless you pull with your foot, or your cruise control doesn't work, then that is proof that the clutch lever is worn. Replace that and then readjust that rod.
It takes some flexibility and effort, but it can be replaced pretty quickly. Be careful when you buy a new one, inspect the inside surface of the hole, because I think its a factory flaw, my new one was. It should be smooth and flat.
CyByte, the rod is connected to the clutch pedal. If you get under the dash and follow the clutch pedal, you will see the rod. I would suggest checking the rubber boot that is at the end of that rod(it is attached to the firewall). If there is fluid coming from the area of that boot, then your master cylinder is shot. You can replace the cylinder(about $60) or you can rebuild it(about $30). I rebuilt mine and it has been fine ever since.
Josh
i have pictures that i just took with my digital camera, i dont see what im susposed to turn. i see something that goes into a metal thing (yes i am leaking fluid out of it) it is covered in some type of liquid type stuff.
it has threads on the side that does not enter the metal unit attached to the fire wall.
i tried turning it but can not get a grip on it, and its completely round. how do i turn this thing? also it appears there are a couple nuts that hold it on also, do i have to loosen a nut or anything first?
it is so cramped in there i can't get my arms to squeeze it with any leverage.
