Ok After 3 months I finally got my Full throttle AFPR. I hooked up a liquid fuel guage onto the regulator and adjusted my fuel pressure to 43.5 psi with line off. (More like 44-45 psi) all is well while the car is running. Fuel pressure is around 36 with line on. I shut the car off and decide to watch the rate of drop.
Heres the results
Right before shut down 36-37 psi (Line attached)
Shut down goes up to 45psi (6:15pm)
6:20 pm 41psi
6:25 pm 34psi
6:30 pm 24psi
6:35 pm 8psi
6:45 pm ZERO PSI
Is this normal.???? In half hour my fuel pressure dropped to zero. I thought that maybe since the fuel pressure guage is right on the AFPR, the fuel pressure measured might be bled off with the return line. What made me check was the fact that one minute my trims were perfect than the next the trims were on the lean side. Are my FIC 650's leaking the fuel pressure? What should I do?
Any one noticed or checked their rate of drop with an AFPR and guage?
Heres the results
6:20 pm 41psi
6:25 pm 34psi
6:30 pm 24psi
6:35 pm 8psi
6:45 pm ZERO PSI
