car is breaking up between 6000 and 6500 in 2nd thru 4th. egt's climb to 850-900. o2's are .82-.86. timing is 18-22 deg. knock 0-4 counts. all this on a PTE gt35 at 30 psi and cheap-ass 110 fuel. when it breaks up boost will climb to 33-35 sometimes.
-8an lines, aeromotive a1000 pump, holley rail, fic 850's. fuel pressures from 38-45 had almost no effect on egt's or power. in fact egt's run 700-750 cruising at 0-5 psi with both 38 and 45 fuel pressures and 94 and 110 fuels. adding/subtracting fuel via dsm translator and s-afc aren't changing the logs much either. eprom is burned (Keydiver) for the 850's, higher idle, 9500 rev limiter, etc.
plug gaps from .030 to .025 produce same results. bp7es and msd 8.5mm wires, stock coils, and Ignition Solutions plasma booster in car.
car ranged from 14.2 at 102 down to 12.7 at 108 first time to track this season. times got better as 60's did (down to a 1.7)...new clutch, fresh engine, etc. everything has 200 miles on it. as soon as the turbo gets into it's power band i get ignition break-up and have to short shift the gears.
the fact that it doesn't do it in 1st makes me think it's the spark being blown out since it's not making full boost in 1st. but then the high egt's no-matter-what make me think...the ignition timing might be retarded and the exhaust valves are opening as the ignition is taking place, hence all the heat in the manifold. i'm going to check base timing and resistance readings from wires and coils....but these are the same parts that went 11.2 @ 126 last year with a smaller turbo, less boost, smaller head, intake, tb, piping, exhaust, etc. i'm dropping 10 mph just in the 1/8th from last year because i can't shift at 8500-9200 where i need to.
anyone have a similar experience or a clue as to why things just aren't adding up?
