HKS VPC vs. APEX S-AFC
774 views 2 replies 3 participants last post by  Van
talon_boy69 said:
Ok, I want to know which one is better...
Neither is better because they are two completely different things.
talon_boy69 said:
I'm not sure if they both do the same but well..I think you can help me.
We'll try, maybe a beer and some more research would be good too.
talon_boy69 said:
I know the VPC is used to eliminate the MASS
It is a totally different intake system that eliminates the restrictive oem MAS. I don't know much more about them , as I'm not part of the "VPC camp." IMHO, the 2g MAS does quite well, unmodified.
talon_boy69 said:
the S-AFC is used to control the bigger injectors,
Yes it can, it can also be used with your stock injectors to fine tune the fuel curve. It is basically an Air Flow Converter (AFC.) That means it intercepts the MAS' airflow signal and changes it, by a %, to what you program it, then sends "your" signal to the ECU. The ECU then "sees" more or less air and opens the injectors the appropriate amount of time. This is best determined by whether you are seeing knock/timing advance, or not, with a logger.
[Edited by Van on 06-30-2001 at 05:17 AM]
