Well just finshed buliding a new sub box for the old lady's new car. Yesterday we went and picked out some subs and I already had a new amp so I said I'll just let her use it to power the subs. But looks like the amp I have is not enought to power the subs properly before I go and exchange amps and shell out the extra cash I like to make sure. Here what I'm looking at..
Pioneer GM-X572
400 Watt 2-Channel Power Amplifier with Built-In Crossover
Features
PWM Regulated MOSFET Power Supply
Bridgeable 1/2/3 Channel Capability
Balanced Isolator Input Circuit
Hi-Volt Input Level Control (200mV-6.5V)
Selectable Crossover: 80Hz, -12dB/oct. (LPF)
Continuous Power: 75Wx2 (4 Ohms), 100Wx2
(2 Ohms), 200Wx1 (4 Ohms)
Peak Music Power: 400 Watts
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4 Ohms)
Signal-to-Noise Ratio: 100dB (IHF-A
Weighted, at 1Khz)
Infinity Reference 1020w 10" Woofer
Sensitivity: 90db
Power handling: 250w RMS
Requency Response: 22~800Hz
Nominal Impedance: 4ohms
Looks like I don't have enough amp to hold those subs, but what if I bridge the amp and run in the subs Parallel.
Pioneer GM-X572
Features
Weighted, at 1Khz)
Sensitivity: 90db
