How does clutch go? Pics ---->
1 reading
613 views 1 reply 2 participants last post by  turbo90awd
this might be a dumb question for some, but it should be a easy answer. Which side of the clutch goes against the flywheel??
OR
AND can anyone tell from the next picture if there is enough clutch left to bother putting it in??
Thanks.
I'm pretty sure that it will only fit one way. If you put the clutch disc on the flywheel and the lay the pressure plate over it, the clutch disc's hub should come close to the fingers on the pressure plate. I'm pretty sure that if you try the clutch disc flipped the other way, it will bump against the bolt heads in the center of the flywheel.
So in your case, the full faced side of the disc would make contact with the pressure plate.
