Maybe all this is due to bad tuning but I honestly don't know what to do anymore. My mods are in my signature and I have tuned the fuel trips with my SAFC to as decent as possible, I was getting no knock while doing a run, and still when I did 0-60 mph acceleration run on a local road I got 6.88 seconds as my fastest time. I am running only 14 psi boost right now but come on, I was running 15-16 psi on my 14b with 450cc injectors and I got 6.4 seconds. I am using a complete professional timer so it's all accurate, on a level road.
Some things I see on my logger are: O2 sensors does not go higher than 0.82V at WOT, my injector duty cycle goes to a maximum of 95%, and I have random very low counts of knock after I added some fuel to some rpm points after having some knock from the previous runs.
I have no boost leaks since I did a boost leak test and also the car feels smooth when accelerating, it's just moving slow. I don't know what the problem is. Am I running too low of boost for this turbo to kick in as it should??
How much boost can I run with these 550cc injectors? From the duty cycle I think these injectors are kinda suffering even at 14 psi..?? I still don't have an exhaust but I will be adding 3" exhaust all the way from the turbo. I doubt that will help that much besides adding a bunch of noise.
What do you guys suggest to do, some things I have missed or skipped somewhere along the road??? I was really expecting to be in the 5 second range with this turbo and all the mods I did. This is absolutely ridiculous. I also launched the car perfect, especially one of the runs it was great. Dropped the clutch at around 3k rpm, just tweaked the tires, which are race tires, and too off without any bogging down or signs of loss of power or rpms. I shifted the gears fast like a maniac... I don't think it was my driving since I drove the car with the 14b as well. ANy ideas?
