So I finally got my logger hooked up and working, and I finally figured out what keeps popping my head gaskets. Ridiculous knock!
I don't have a way to export my logs from my palm, so I'll just give you the vital information. All of this can be replicated, and it's very predictable.
@ WOT
RPM: 5250
KNCK: 42
O2-R: 0.80
INJD: 39.8%
TIMA: 4 deg.
Typically I see timing retarded to 0 if not -1 or -2 degrees.
After my first log, I figured that it might just be the crappy old knock sensor going crazy, but I installed a fresh OEM knock sensor this morn, and same thing happened.
What I don't understand is how my knock can be that high if my INJD is that low. I've tested for boost leaks, and I have none. Currently running 14 psi. (1 bar spring in the Tial). If my INJD is that low, doesn't that mean the ECU isn't seeing enough airflow to necessitate holding the injectors open longer? (resulting in more fuel.)
FYI: If I lay off WOT, I can go all the way to redline, just a lot slower than I'd like.
So what could cause this? BAD FPR? I can't think of anything else.
EDIT:
Forgot to list my mods.
Stock 6-bolt w/ BS removal
Turbonetics 50-trim bolt on
255 LPH w/ 780cc's
Keydriver Stage 3 w/ compensation for injectors
Big front mount
@ WOT
RPM: 5250
KNCK: 42
O2-R: 0.80
INJD: 39.8%
TIMA: 4 deg.
EDIT:
255 LPH w/ 780cc's
Big front mount
