intake and bov causing the car to jerk
4K views 53 replies 19 participants last post by  kevingmorales
well i installed an jdm cold air intake and a greedy type s bov and its giving me problems when i step on the gas all the way after 3,200 rpm after the turbo kicks in and its starts to jerk back and forth Help Me please!!!!!
oh i got a friend the also has the same car as me its an eclipse gst 95 turbo and he istalled his bov with the intercooler kit and he say it doesnt give him any problem , and you know what he said to that me fuel filter has tu be changed and his fuel fielter has not been change well he doesnt know nothing because when i had my stock intake and stock bov it didnt gave me any problems at all . can you help me ???/
Why don't you put your stock intake and BOV back on and see if the problem persists? It could just be a coincidence that something else went bad at the same time you did the work.
Also, do you have a link to the ebay intake that you bought so we can see what exactly you have?
well i dont know what might be the problem.but i do know when i had my cold air intake pipe on it it did the same thing. but then i took off the cold air intake pipe and installed the stock pipe, and then the problem went away.then i bought the greedy bov type s with the flange adaptor for the stock intercooler pipe for the 2g eclipse, and when i was done installing that bov when i took it for a spin it did the same thing ,first i tried to adjust it hard,then i adujst it to soft , and then in between and it still does the jerking. pease im concern help me please !!
So, you installed a intake pipe and the problem started. You then replaced it with the stock piece and the problem went away. At this point you bought a Type-S and installed that, the problem came back. So what is on your car right now?
Oh, and if you would combine all of your thoughts into an understandable paragraph including punctuation before posting it would help.
kevingmorales said:
it cost like 40 bucks,is that what you were refering to?
Just for some future info, the "ebay knock-offs" are utter garbage. Save and by a REAL Greddy Type-S BOV.
Ebay's only good for little things non-performance-wise, unless it is a used/new part that IS real.
For example; headlights, bulbs, clusters, mufflers, etc...are okay to buy from there.
But stuff like turbo's, BOV's and more "technical items arn't such great purchases on ebay since 99% of them are knock-off's.
For an example; My buddy bought a AFPR for his car. And well the regulator "pooped-out" on him and caused his car to run so lean that it ruined his motor.
you just gotta be carefull what you buy off of ebay...
In my opinion, ut all of your stuff that you repalced abck on and see if your problem presist...
