internally gated 7cm FP Green turbo
17K views 110 replies 32 participants last post by  gimmie11s
This is a review for the Green label turbo sold through Forced Performance. ( www.forcedperformance.com ) I ordered mine with a 90* elbow welded to the compressor outlet to allow the use of my lower intercooler pipe. The turbo bolted on without any hassle. Start to finish ran me about 2 hours.
This turbo replaced a MUTT L3 with a TA housing and any comparisons in this thread are made to that turbo.
I decided to go with the Green because of its reputation and the numbers it has put down on numerous other cars. I decided to go internal for a) Cost and B) the car is already set up for an internal gate. There is quite a bit of concern about whether a large turbo such as the Green is doable with an internal gate. Concerns are about its ability to hold lower boost without creep and its ability to run higher boost without blowing the 34mm flapper door open.
The cost of the internal gated turbo is approx. $150 more than in externally gated turbo because of the additional materials needed (actuator, flapper, etc.) but in the long run is cheaper when you consider the cost of a nice O2 housing flanged for a gate and the external wastegate itself. In my case I had no plans on running anything less than 20 ever so the internal gated turbo was a viable product for me. If you plan on running 15# on the street or while waiting for the rest of your supporting mods than this is not the turbo for you.
In my case the lowest boost I could run stable was 18#. The highest I have run has been 24#. The adjustment between these two boost levels is not merely a boost controller change though. You need to adjust the actuator rod to increase or decrease the wg tension as needed. I am confident that the turbo will run higher boost though without blowing open the door based on the amount of tension I can still add with the actuator rod. FWIW I am using an AHP tubular O2 housing which I am sure is helping me attain stable boost.
In comparison to the MUTT turbo this Green flows marginally more air at the same boost level. As reported by the AFC I am seeing roughly 75-100Hz more air through the MAS. I believe that the Green is more efficient at the same boost level though as my timing is much better with all other conditions and settings the same. Boost onset is the same when compared between the two turbos. The Green hits a full 20# right at 4k when rolling into the throttle at 3k in 3rd gear.
I have no track times for comparison because everytime I have scheduled a day to go I have gotten rained out. :(
Go ahead....ask away. :)
Were intake temps consistent with those when you did your initial tuning with the ETA 32?
stevo said:
What made you go with the Green over other turbos such as the L2R?
if i read it correctly, he wanted something that had proven results in similar applications.
Well I have a daring controversial question. We know the ETA 32 has a 50 trim Garrett. Does the Greens' compressor wheel look the same? Inlet size measure the same? You say the spoolup is the same. You are seeing a higher Hz count eh. And better timing? No other changes at all? You havent messed with the AFC? You dynoed about 280 something with the ETA 32 on 18 lbs right? I dont remember. It will be interesting to see you hit the dyno with this one.
Maybe youll be the next pump gas king. 22 psi on pump gas putting down 420 horses like Dre. Good luck with the Green!
Josh
#6 · (Edited)
This should be an awesome review. As time goes on, he is in a good position.to give comparison related feed back, on both. I also would love to see some dyno numbers at the same boost level. From what he posted it appears the green is more efficient and flows a tad more.
UmmM...i believe Dre blew that motor not to long after getting 420whp on pump, i wouldn't suggest attempting this unless you plan on a motor rebuild often...
why would you change out turbos without seeing what yours could do first? some turbos have different effects on different supporting mods...yes the green is proven but you already had a similar turbo on your car...you may have put out similar if nto better numbers then some green owners...:rolleyes:
Look! So what if Erik wanted a different turbo. He liked the Green, so he got one. I aws in the same boat. I had a 20G, didnt really do anything with it. Then went and decided to slap on an L2R, for no other reason, then because I liked the idea of it. I dont blame E for being carefull. He has every reason to be.
Glad to see you came out and spoke on the internal gated green. I don't care about you changing turbo (hey it your money). My main concern was if the internal gate could hold boost. I plan to run on pump gas also and have my boost up around 18psi. Is this safe I mean to run 18# on pump gas.
BigBalledDSM said:
mutt 3 and green are similar
hey well if he has the money to spend and time to do it then whatever, just in my opinion i'd hate to take a turbo off my car and never know what it might have done
LOL, no they are NOT similar!
The compressor housing alone makes it not so, not even counting the different turbine wheels...
Correct me if I'm wrong Erik:
As far as not getting another unproven turbo, once bitten twice shy eh?! The Green is proven to rock and roll and a ball-bearing center section just might turn out to be a risky thing...
If I may say so, Erik's eta32 turbo never did work quite right for him as far as I've seen him post here. Hell, he went thru two of them. Enough of that, move on....
I have a strange feeling that this review isn't gonna be liked by some, hehe. Anyways, my ETA32 has performed pretty well up here and is now spitting oil out the backside at high boost, but I've beaten the hell out of this thing and then some. :D
I'll be going bigger this winter...:tree:
Good luck Erik, keep us posted man!
Believe it or not I didn't actually compare the wheels visually between the two before I sold the MUTT. Not sure why. I am sure they were the same though. Inlet diameter is the same between the TA housing and the TD06.
I messed with the AFC but only to get the car back to a similar state of tune. Boost level has remained the same.
I put down 298 at the wheels with the MUTT3 on 18# and pump gas. I am looking forward to getting some numbers with this turbo as well but the car is down temp. after a small accident.
Josh
Yes the turbos are similar on paper but with more experience I am learning that what numbers say on paper don't always translate into real world performance. Efficiency and longevity are what I expecting out of the Green over the MUTT3. Perhaps I didn't pull all of the potential out of the MUTT before selling it, but its potential was not worth me holding onto a turbo I wasn't comfortable with.
BigBalledDSM said:
careful?
L2R and 20G are not similar, mutt 3 and green are similar
It is perfectly safe to run 18# on pump gas if you are tuned correctly.
In all honesty I cannot recommend the turbo over products I have not tried. I would recommend it hands down over both the 16G and the ETA32/MUTT3. There are many options available to the DSMer these days, many of which I have no experience with.
stevo said:
So I am guessing you would suggest the Green over the other street turbos out?
Keep us updated.
Definate seat of the pants difference and also the G-tech reports a difference as well. I wouldn't go using G-tech numbers as a replacement for track numbers but there was a decrease in ET when the tests were performed in the same testing area under similar circumstances. What I usually do is run 5 times and average them to give me a number to compare. With this crude test I have dropped about 3 tenths over my previous setup.
colonelfox said:
Since you have no dyno or track times yet, what about the buttometer? Any noticeble seat of the pants power increase?
That's damn good for just bolting on a turbo that is supposed to be comparable to the level 3. Gtech's aren't as far off from real track time as some would think if you set it up right.
Does anyone know if FP gives the option of upgrading a GREEN to a RED later down the road? It might make more sense to start with something that doesn't have to be used to it's least potential to avoid killing my stock motor. I wanted to end up with a RED, but I blew my 16G permanently, and can't stand the T-25. I might just get a GREEN with my Christmas bonus. I've noticed more people that are happy with the performance of the GREEN, than with the Mutts.
