I'm brining my engine to the machine shop very soon for my stroker build and I want to make sure they build it to spec. I know I need to provide them the piston to wall clearance, but what other clearances/specifications do I need to be aware of? Is there anything to be done to the camshaft caps? Here is what I am planning on having done:
8.5CR Mahle Pistons
Eagle Rods
Eagle 100mm Crank
ACL Race Bearings
Kiggly Girdle
EVO VIII Springs/Retainers
HKS 264/272 Cams
AEM Cam Gears
New Valves, Valve Seals, Valve Guides
Hot Tank
Resurface block and head
Crankshaft Hone
Piston .020 Bore/Hone
Balance Rotating Assembly
Pressure Test Head
3 Angle Valve Job
8.5CR Mahle Pistons
Eagle Rods
Eagle 100mm Crank
ACL Race Bearings
Kiggly Girdle
HKS 264/272 Cams
AEM Cam Gears
Hot Tank
Crankshaft Hone
Pressure Test Head
3 Angle Valve Job
