Ok I have a few questions. I have a 99 gsx 550 injectors, 190 pump, big t28, tubelar hedder/o2 housing, 3" down pipe, 3" cat back, fmic, hard pipe kit, act clutch, greddy bov, safc 2, gm maf, maft version 2.1, auto meter wide band, egt, boost, BC 272 cams, K&N round filter,
1 I'm installing a maft and Gm 3" maf and would like to know how to use the stock Maf for baro. and Iat sensors, What wires to hook up for that? I know I will need to tap into the 12v and ground for the gm maf, but do I just cut the maf signal wire and connect to the maft output? Also what color is the maf sig return?
2 I install ths gm maf and maft today and the car was running rich!!! I had it set up for 550 injectors and it was still rich so I had to turn it to 450 injectors and adjust the idle fuel trim to lean it out my fuel trims were at (long 1.5-2 and short was switching good after). Is this normal or could there be something wrong with the maf or maft?
Please no comments on how much Maft and safc suck. Thanks for all the help guys.
