Mizumo rebuild kit?
12K views 5 replies 5 participants last post by  The_EE
Yup, I used a ebay gasket kit on my build but used a mitsubishi mls head gasket. And last week I had to pull the front case off the block to replace the crappy paper gasket that kept leaking oil.
Definitely go oem with the head gasket and front case, ofh and just about any other paper gasket. Like ralliartGS-T stated.
OEM without a doubt. There is a reason why that kit costs $200 and change. Because its worth far, far less.
OEM will be more expensive now but cheaper in the long run because the parts should last. When you buy these cheap unknown companies bullshit, you get cheap bullshit. You cant expect it to last because their quality is unknown.
Go with what is tried and true, quality aint cheap and cheap aint quality.
