Check your turbo's compressor outlet for OIL. If you heard it gurgling from the depths of the motor when doing a boost leak test. Then you could very well be shoving air past the turbos seals. When mine did this, it also vomited a ridiculous amount of oil back OUT of the compressor housing and a half quart or more down into my fucking charge pipes...
(REAL fun the first time I opened the BOV and showered a cupful of oil into my engine at 30+psi) not...
I have not had the balls to do a leak test since. But I did purge all the oil from the system, and the turbo has not displayed any problems since.
A side note; if you really have 2700 miles on your "brandy" new engine and you haven't exceeded 4000 rpm I almost might blame the ring seal... it is possible, but not guaranteed that you have generated the correct loading to ensure proper break in and ring seal. I hope it saw 4000rpm at WOT and heavy deceleration in like 2nd gear... repeatedly...
If it is rings, a compression test would show it, adding a small quantity of oil will show an improvement most times if it truly is rings.
Although if the turbo is not new... I wouldn't doubt that you could possibly be pushing it up the oil feed line, or out of the drain tube.
As to the recommendation of only using 5psi to test a car. If you have a turbo doing what mine is, you may be forced to. But this is NOT THE WAY TO DO A BOOST LEAK TEST. So if you recommend doing it that half ass way again on a public forum where someone might just take your advice Need2fix, I will drive on down there and put my foot in your ass.
There are sneaky leaks that only develop around or AT your desired boost level. Which means we test PAST our desired boost level to be SURE no leaks develop throughout our boosted range.
Period.
Everything's well and good until you shoot an IC pipe off at 30+psi and it comes off with enough force to shatter expensive things in your engine bay... while your driving... instead of in your garage...
