1 - 2 of 17 Posts
White91TalonTsi said:
Alright so i got my new Autometer Carbon Fibre series boost guage today and looks great :cool: . But when I ran the Turbo is read 14 maybe even 15 psi :eek: and My MBC isnt even on.
It will not hold the boost though, it shoots up to around 15 then drops to about 11 at high rpm's. :confused:
So...is this normal?? Im really confused if I just have some mad boost creep (Its a really cold day, maybe turbo running really good?), or is the Guage not accurate or what? :mad:
Please help guys I dont want to wreck my car! :)
you got nothing to worrie about, a stock dsm can hold 16 psi safley. aslond as you dont go over that you should be fine.
I would bet that your gauge is just fine but just to be sure when you turn the engine off it should go to 0 and when idling it should read between 15-20 units vaccum. If it does this chances are you are boosting that much
Do you have an exaust or intake mod? That could raise boost from factory levels. I have a turbo back exaust on my car thats all and i run 12 psi till 5000 rpm then i spike to 15 psi just to give an example.
If you dont then it could be a problem with your acuator not opening the wastegate as quick as it should. like a leak in the vac line going to the acuator or in the acuator itself.
1 - 2 of 17 Posts
