well i figured i have this posted on a couple non dsm forums, so i might as well post it where it actually belongs lol
Complete Spec list:
Engine:
6bolt 20 over all nice and fresh
fully balanced rotating assembly
pauter rods
weisco pistons
pro-gram billet steal main caps
acl main and rod bearings
Arp main studs
Arp Rod bolts
Arp main crank bolt
balance shaft eliminator kit
new oem water pump
new oem oil pump/ front cover
new oil pump pick-up
Cylinder Head:
Arp head studs
Fox Lake CNCed cylinder head 291cfm intake 279cfm exhaust
hand polished exhaust side
50ra finish
3g lifters
Ferrea 6000 series 1mm over intake and exhaust valves
Ferrea Bronze intake guides
Ferrea Copper exhaust guides
BC springs and Ti retainers
BC 280 cams
Greddy Kevlar timing belt
fidanza adjustable cam gears
Intake:
JMF intake manifold bored for a 75mm TB
Power 75mm TB
30"x12"x3" fmic
magnus heat barrier intake mani gasket
Turbo/exhaust:
DNP t4 divided flange turbo manifold with a 44mm wg flange
PTE T-67r BB .70 a/r compressor and .68 a/r exhaust w/ anti surge compressor housing
High temp black ceramic coated exhaust housing
Tial 44mm wg
hks ssqv bov
thermal R&D catback
Slow boy racing steel braided oil return line
slow boy racing steel braided oil feed line and
Goodridge oil filter for the turbo
copper metal exhaust manifold gasket
Suspension:
full Tein Flex Coilovers
rear and front sway bars
Fuel/management/Ignition:
Fuel Injector Clinic 1050cc injectors
Full Blown Motorsports dual pump braket
twin 255hp walbros
aeromotive fuel rail
aeromotive 1:1 fpr
-6 SS fuel feed line
dsm link
coil on plug
Bpr8es spark plugs
Tranny/clutch:
stock tranny for now
Power Train Technologies Twin Disc centered iron discs
new oem throw out bearing
new oem clutch slave cylinder
symbrowski shift kit
B&M short throw shifter
slow boy racing shifter bushings
Cooling
160 degree t-stat
Misc.:
Jay racing alternator relocation
Complete topline engine rebuild gasket set
Fluidamper harmonic balancer
new starter plate
new oem knock sensor
new oem oil pressure sensor
new oem timing belt tensioner
new oem timing belt idler pulley
new oem timing belt tension pulley
there might be some things that i am forgetting at this time, ill add those later, brakes, ems and a couple odds and ends is all thats left
the car
old 7bolt motor, threw a rod through the block
new 6bolt motor with broken ring lands
and the beginning of the build
this is just a cylinder head i had laying around so i am gonna show the before and after
Complete Spec list:
Engine:
pauter rods
weisco pistons
Arp main studs
Arp Rod bolts
Arp main crank bolt
new oem water pump
Cylinder Head:
Arp head studs
50ra finish
3g lifters
BC 280 cams
Intake:
Power 75mm TB
30"x12"x3" fmic
Turbo/exhaust:
Tial 44mm wg
hks ssqv bov
thermal R&D catback
Suspension:
twin 255hp walbros
aeromotive 1:1 fpr
dsm link
coil on plug
Bpr8es spark plugs
Tranny/clutch:
Cooling
160 degree t-stat
Misc.:
new starter plate
the car
