1 - 6 of 6 Posts
mirzasDSM
im haveing a problem my radiator fan isent kickin over and my heat gauge goes up how do i fix this. is there a way i can wire a switch in to manually turn it on? beacuse i dont want to over heat and bust my head
You could also get an automotive relay, inline fuse and remote switch to do it yourself, but I would follow turbobird14's suggestion first. Also, if you unplug the fans from the harness you can test the fans to be sure they're working properly by connecting a jumper from the battery to the power and ground pins on each fan.
I had the same problem also...It was the sensor that screws in the bottom of the radiator like WBaginski said. I think its called a fan relay switch. Replace that before anything.
1 - 6 of 6 Posts
