1st... I check my oil level every 2 weeks or so.
Car has no oil leaks.
Fairly new built motor with good compression numbers.
So car was down for a while because of a leaky intake manifold gasket. It was sitting for 2 weeks. Change the gasket friday before leaving to San Diego. Run the car at idle. Check my oil pressure which was normal when cold. But when warm I was getting 40 psi of oil pressure which isn't cool at all.
Shut the car off in a hurry and go to check dipstick. With the world crushing down on me I see only a spec of oil showing. :tat:
I don't know but I think I might have ran the car like that for couple days.
I seriously don't know how I'm losing oil. Never was burning oil before, so that was a big shock.
Anyways... I'll probably have to check my oil pan + bearings tomorrow.
Then if by chance there are no mechanical damages, I'll have to find out where the fuck the oil is going?
I'm guessing turbo seals? Will have to check my intake pipes. I was checking shaft play just last week though. Everything is fine. There is no smoke under wot. I'll redo a compression test tomorrow.
Any input? :dunno:
I'm getting more and more distant from that car.
