My car always grinds when putting it into reverse. Even when the clutch is through the floor. My guess is i need my clutch realigned but does anyone else know wtf to do? And how much $ is it to get it realigned?
f i just bought the car. there is no way i can afford that now. i'm just gonna have to work around it.RippinGSX said:Time for a tranny rebuild.
Yeah, good luck with working around it.Eclipse GSX 61 said:f i just bought the car. there is no way i can afford that now. i'm just gonna have to work around it.
Very unlikely. If it were the master or slave, he would be having more problems than just reverse. It would pretty much grind going into any gear because it won't disengage the clutch all the way. Same thing as when your clutch fork is bent or about to break.ricr1990 said:Master and slave!! I had a similar problem and it fixed it next first is going to go.
No such thing as having the clutch re-aligned. I would bet your clutch fork is bent and about to snap on you.Eclipse GSX 61 said:but if thats my only problem with it is that grinding from nuetral to reverse and maybe every once in awhile from first to second (almost never) can't it just be realigned?
And what fixed that problem for you? If the clutch isn't disengaging it's usually one of three things or a combo.90redgst said:Why the worst case scenarios? I had the same problem and it was my clutch not fully disengaging.
Nope, just been through all this crap already man.oldman said:Sounds like Rippin works on commission for some tranny re-build shop.![]()
I'm sure you have but one person's experience doesn't always define all possibilities, pulling the tranny should always be the last option, not the first. You may be right at the end but not until all other possibilities are eliminated. For example, no one in this thread has even asked OP if he has the same shifting problem with the engine off which is step one when troubleshooting tranny/clutch issues, pulling the rebuild trigger is a little too early if you ask me.RippinGSX said:Nope, just been through all this crap already man.![]()
Proper sentence structure, proper grammar and capital letters where required please. Read the rules.Eclipse GSX 61 said:well i need to figure this out cheap bcz go figure my f'in driver side door handle just snapped on me.now i need to buy a new handle and get it painted and installed. any good local shops to check this issue out in PA?
Broken said:Try double clutching it. For all of you with shitty synchros, it goes like this:
