Hi, lately I've been experience loss in power in my 1999 eclipse GST. On the weekend I did a BLT for the first time and I had a few leaks:
Lower ICP, BOV, FPR adjustment screw and fuel injector o-ring.
I corrected all except for the fuel injector o-ring as I ran out of time. When I started my car the idle was terrible and it eventually stalled out. I looked at the fuel pressure regular gauge (aeromotive) it read 20PSI instead of 40PSI.
My questions are
-would the drop in fuel pressure make that big of a difference to my idle? 20PSI is not nothing there is some pressure.
-is a lot of boost lost at the injector O-rings? should I fix this asap?
-I sprayed a lot of soapy water in my engine bay while performing the BLT. could this be a reason for my rough idle?
Thanks in advance.
My questions are
Thanks in advance.
