The car has The following Modifications.
AGP RS49T 50trim Turbocharger
Denso 760cc Injectors
Walbro 255 Fuel pump
AeroMotive Adjustable FPR
Clutchmasters 2500lb clutch
ACT STREETLIGHT flywheel
AGP Bar and Plate Short Routed *big* FMIC
1g bov
DNP SS Tube Manifold
Tial 40mm Wastegate
SS 3 inch 02 Housing + FULL 3 Inch SS turbo Back exhaust. (with wideband 02 bung welded on)
Boost - EGT - and Oil Psi autometers on the Pilliar
Blitz SBC ID III to control the boost
a MAFT setup mounted in the glove box to adjust the fuel.
Findanza Short Throw Shifter
I have the car Rough tuned with the wideband for 15psi with No knock.
http://i39.photobucket.com/albums/e163/black797/talon/Dsc02154.jpg
Should i push the boost more? What would be the next step to higher psi.
