Hi, I have a '92 Eclipse GSX. I acquired it blown up. It is an auto. tranny. I replaced the head with a '93 Turbo Manual trans. cammed head. I put in 1 new piston, new rings on all 4 pistons. I did it up right. I set the ignition timing as per factory specs. I am a mechanic and try to do everything right the first time as I don't like doing the same things multiple times on the same vehicle. I noticed that at idle I can smell unburned gasoline. There are no external leaks. While going down the road with the moonroof open, you can also smell raw gas. I just put in a new O2 sensor. It idles at the right RPM, but only at about 8-10" of vacuum in Park or neutral. Is this all caused by the Manual trans. cams with an auto. tranny and automatic tranny ECU ? It runs great and gets maybe 20+ MPG going down the road. I live at 6000' altitude if it helps for any reason. Any help is greatly appreciated.
Thanks, Rick
Thanks, Rick
