I figured since nobody else has done a review on this turbo, I will...
First a little about the turbo. Its actually the eliminator turbo from TC.com that has been machined by slowboy racing. SBR ports the exhaust side of the turbo and upgrades the WG flapper to a 34mm. If your not familiar with the eliminator turbos, its a mitsubishi center cartrige (direct bolton
), tdo5 turbine, 20g compressor, and a modified t3 Airresearch compressor housing (no need for a j pipe). I was a little disappointed with the compressor side of the turbo. It was bigger than the compressor housing from the t25, but not by as much as I was expecting.
Install was easy. No different than installing any other turbo except you dont need the J pipe, which cuts down on cost. You do need to file the holes on the oil return line closer together though, just like when you install any other mitsubishi turbo onto a 2G. I also ported the exhaust manifold to 7cm and installed a ported o2 sensor housing. I used the RRE oil feed line, which is a very nice piece. Install took about 5 hours including running to the hardware store a few times. To cut down on time I didnt drain the coolant from the radiator, I just clamped the two hoses with vise grips. Worked very nicely.
I love how the turbo performs. My car pulls all the way through redline now. WAY more top end power. I still need injectors and DSM link (both are on the way). Boost comes on strong and fast. Lag is WAY overrated. Not much laggier than the t25, but there is more power at lower boost levels. I am experiencing boost creep though. I think I need to gut the o2 sensor housing a little more to get rid of it. Boost holds at about 15psi then creeps up to 19psi by 7000rpms. Once I install the injectors and DSM link Im going to be running 19 psi all day... the car seems very happy there.
BTW... Lets keep this thread about the 2g 20g and NOT other turbos. I dont want this thread to turn into a "which turbo is better" discussion. I know a few other drivers on this forum have this turbo and Im curious what they think of it.
