1 - 18 of 18 Posts
NTDeamon
I have been stationed in south korea for a year now and get back to the good ol USA in APR. I have been away from my beloved car for over a year at this point and I would like some help with a few questions. First I am upgrading from an E316g to a Bullseye 20g :) I have all supporting mods as far as fmic intercooler blow off valve and afpr as well as a 255 rewired. Can I still use my safc to tune with? I have 750's and am running the 2g maf. My friend has a stock Evo ecu hes looking to get rid of will that work in a 1g? I would like to run 24psi is that an ok amount to run with safc and 750's? Lastly I forgot to mention but I also have a wideband boost gauge boost controller and a logger.
Thank you,
PFC McBee
Discussion starter · #12 · (Edited)
Well I could keep that in mind for the near future but an easier way would be to run 650's right ? Would those work with the 20g? The only reason im strapped for cash right now is because of my wedding and pcs move. I just need to have a temp solution for like four months.
So it currently isn't running? I was under the impression from the first post that you were going to be upgrading.
Discussion starter · #16 ·
Well blown motor my mom took it for a drive and something happened and smoke just started pouring out from under the hood haha :( I just found out when I started this thread. Sorry for the confusion. I just want to know can I run the 650's with the 20g on like maybe say 10-12psi for the time being. I have everything for a full engine over haul.
Discussion starter · #18 ·
I need to rebuild it in two weeks. Which for me is easy. I have 750 inj right now the 16g is fried along with the head and valves. I have everything needed to rebuild and overhaul the engine. I just picked up a used 20g from Hawai5oh for 200.00 and only have the safc to comp the inj. I want to know if 650's will be able to support the 20g. If not I am going to use the members service and have my ecu socketted and a chip burned set for 750's then just use the safc for fine tuning.
1 - 18 of 18 Posts
