Hi there guys. I'm doing a little research about upgrading my engine at the end of the year. I interested in doing a stroker. I'm looking at the Eagle 2.3 crank & rods with some 9:1 pistons. How many people are running this combo. At the moment I've got a big 16g, but want to eventually upgrade to a TD05 20g. Will this turbo work well on the engine combo. The car is a daily driver that might see the drag strip a couple times to hopefully shut a few of my V8 mates. I'm wanting to run low 12 in street trim on under 20 psi. Are there problems that occur with these stroker engines I should be concerned about. Should I keep the balance shaft to eliminate any unwanted vibrations. I will get the engine balanced before installation. I have a very good mate that runs a machining shop that will be doing all the work. I would like to hear some feed back from memebers that are running this combo.
