how much diff?
all i know is that on a mr2 a td06 will haul.
can we use the td06? all i hear on dsms is the td05
Is it true that the SBR 20G has a TDO6 compressor housing? The SBR website says that the "SBR uses a modified T3 compressor cover, with a welded 90 degree elbow for easy fitment." To me this sounds almost like TC.com's eliminator.DRW said:The SBR 20G is a 20G compressor wheel inside a TDO6 compressor housing and on the exhaust side it has a TDO6 turbine wheel inside a 7 cm housing. It is one of the best 20G's out there. The Buschur Racing 20G differs by using a TDO5 turbine wheel clipped about 20 degrees in a 7 cm housing. It is also an excellent turbo.
If the SBR 20G is infact a TDO6 housing with a TDO6 turbine wheel, and is a direct bolt on for 2G's, then this sounds like the turbo for me!! But, from what it sounds like, the SBR 20G has a modified T3 compressor housing.
? tuning is the key. Everyone I have spoken with that has had a 20g gets full boost by 3700-3800rpms...whitegst97 said:Ok the TD06 20G gets full boos at around 4k. I think is a bit too big, damn i just got my 7cm ported housing and i can't get all the power out of the turbo 4k to 7.4k is not enough to get the full potential i think you will have to race from a rolling start til like the end of 4th gear.i need more RPM's but my 3rd gear gets a little to put it at 7k, dsm's
20g with stock injectors @ 17 psi?!? AND YOU LEANED IT OUT??whitegst97 said:Another thing, i have tuned a bit bu ti can't get more than 17 in timing, and the RPMS 4k to 5.5k the timing is at starting at 8 to liek 13, could that be because thats when the turbo starts to pull? Im running at 17psi with the 20G and stock 4540cc's, they have been leaned out from 4k to 7k to -11,-12,-13's. Could it be that the car is tuned to give max timing, but these injectors dont' allow it to flow enough gas to increase the timing.?? Thanks
That is why he didn't hit fuel cut because he leaned it out. He has tricked the ecu into thinking that there is less air than what is really there. Thats why you wont hit fuel cut with bigger injectors because the ecu is tricked by lowering the AFC. And -12 is pretty lean for the 450's.centxdsm said:All cars are different, that's for sure. Yet i fail to see how you could lean out the stock 450's, aside from what turbo you have, without hitting fuel cut.
