what do you all do: leave car running or turn it off?
1.6K views 15 replies 15 participants last post by  DaveSM
I want to clear up a question i've had for a while...what are you suppose to do when you let your car sit for 5-10 minutes? say you need to run into the house for 10 minutes, are you suppose to turn it off? i've heard people say you can burn 1 gallon of gas for 1 hour of idling. but i've also heard people say you burn the most gas on startup.
ok, so maybe it's not that important, but this has been making me think.
I usually up the turbo timer, and lock the doors ;) I usually have it set at 2min., so my goal is to always run inside as fast as I can and get back to the car before it shuts off. Thats how I usually judge if a fast food joint is really "fast food" :D
DaveSM said:
Starting a car takes the same amount of gas as 10 seconds of idling. So if your not waiting for the turbo to cool off, I wouldn't let it idle for more than like 30 seconds.
yah the whole stigma about idling vs starting is for larger DIESEL (spelling?) engines... or 18 wheeler type trucks, they aside from having the HUGE tanks to support idling forever... they are more efficient to just leave running then kill/restart at every stop you make (such as deliveries and such)
Idling down is good for the turbo and maybe bad for the valve train .
More wear at idle than at other rpms. It is'nt so bad with a roller valve train like ours.
Flat tappet muscle car engines with stiff valve springs... excessive idle time is really bad for that
If you have'nt been running hard and the turbo is cool just shut it down.
If it is hot and you like that turbo you should idle or drive slow untill it is cool.
The ECU I'm looking at has a special turbo cool down routine where at low rpms it runs rich when this feature is on. This lowers EGT's for the cooldown session.
I have other tricks I'm working on of my own as well :D
I know people may want to call bullshit on me for this one, but I used to work in a service shop where I grew up and there was this railroad transportation company (transported railroaders from train to train etc) that had their transport vans serviced with us, and I kid you not, they were getting 500,000+ miles on these Dodge vans. When I asked how they do it, they said that they almost never turn the engines off (they are in use 24 hours a day). When they are waiting at a stop, they leave them idling. The only time they turn them off is to buy gas and to have them serviced. I know I can't prove this, but I promise it is true. I saw it with my own eyes. Crappy Dodge vans with 500,000+ miles un a motor that was never rebuilt.
Getting crazy amounts of mileage on a vehicle that doesn't get turned off isn't bs at all. Cars are made to run at the proper operating temperature with the proper oil temperature, etc, and so always being at that temperature is less wear on the internals.
