700 is a tall order to build, most people would crap themselves if they rode/drove anything over 400. Longevity issues occur in the strokers because of the rod to stroke ratio(I believe that's what it's called). What happens is the rod is at such an angle because of the larger circle made by the crank, and the skirts of the piston push on the cylinder walls, or something like that. I still stand by my opinion though. Like I said earlier, 700 is a tal order, but it can definitely be done. You'd need an EMS of some sort ofcourse, 1600cc injectors, a bosch 044 fuel pump, bigger fuel lines, a twin disc clutch(if 5-speed), hella-big cams, probably aluminum rods to rev it out. The list goes on and on. See if you can ride in someone's high horsepower car, and see if you really think you can handle it, or if you really want to go through all the expense. If you still decide to go through with it, make friends with your local speed shop, you'll be one of their top customers. I think it's Titan Motorsports that's down there in Fl, they could probably help you out, and expect to pay, they're high dollar guys.
