When the vacuum nipple on the J-Pipe is missing...
4.4K views 10 replies 7 participants last post by  RippinGSX
Guys, I installed my ETE32 the other day.
This beautiful Turbo came without the nipple that usually comes mounted on the J-Pipe.
What am I supposed to do, add it to the Lower intercooler pipe or what?
Pls enlighten me, right now I am running with the Wastegate connected to a positive vacuum source, and I chose the PCV Valve... :rolleyes:
The car idles like crap, I barely drive it anyways.
Thank you all in advance.
Walter
run the mbc from the bov hose, not the pcv hose.
Yes, he is right. That is where I would run mine if I had a need for a MBC =).
There you go
RippinGSX said:
You can drill a hole and add a nipple, it's easy and they can be had at just about any hardware store.
Guys, that's actually the type of info I was looking for.
Has anyone ever done that?
I know it's easy, I've done much more delicate and dangerous jobs on my car (retapping the head threads for the valve cover is an example) but I would like to know from knowledgeable people where exactly should I drill and tap the hole... on the Turbo J-Pipe?
On the lower IC pipe right after the coupler?
On the lower IC pipe further left towards the passenger tire?
What's the best way to add a nipple to the IC pipe?
The newones that came with my DSM-Performance Kit are extremely light and thin compared to the good-old Dave Brode one. I surely won't have enough meat to tap a thread in there.
Any other advice please?
- OR -
Do you have an alternate way to connect my MBC?
If I connect it on the WasteGate and Type-S nipple, what will I have to do with the intake manifold nipple that is currently connected to the big nipple on the Type S?
Any alternative?
Thank you in advance guys.
Walter
Re: There you go
DSMaddicted said:
- OR -
Any alternative?
Walter
Walter...
Don't add the nipple...
Just put a "T' plastic connector on the vaccum line that goes from your intake manifold to Type S nipple. Put a vaccum line on the remaining open port of the "T" and run it to the MBC. That's the correct way of hooking the MBC to the BOV line...;)
Re: Re: There you go
Blackboost said:
Walter...
Blackboost, thnx man, that's what I will do.
That's the way TurboXS reccomends to connect their MBC after all...
Thank you, I guess this thread could be :lock: then... :p
Walter
Brazed nipple to compressor outlet (J) pipe. Detects high boost a little faster to open wastegate more timely.
My point exactly. James, you know there is no one correct way to do this as each works and has it's benefits ;) Although that is the correct way to hook into your bov line some people such as myself have had better, more accurate results using the J pipe method.
