Some OEM companies do sell aftermarket, but that doesn't mean their aftermarket parts are of the same quality. Often they will use poorer quality parts that they can't use to the OE customer. This isn't always the case, but it can happen quite often. For example, pistons could be made out of a lower grade material, to looser tolerances, bigger weight differences, looser surface finish requirements, etc,... Some aftermarket forged pistons aren't that expensive. Pistons, rods, bearings, studs, are engine parts that I wouldn't try to cut corners on.
Oh yeah, to the guy talking about the 20 psi is 20 psi. Pressure means almost nothing. The amount of air in the cylinder is what's important. The resulting pressure (final pressure, not initial) of the amount of air being compressed is what creates the significant load. So a low pressure from a high flowing turbo can have a higher force, than a high pressure from a small turbo.
