Finally got the car started tonight. I couldn't get it started one day in October and I didn't really have any time to look into the issue nor any need to as I was driving the Durango. So this weekend I dragged it into the barn, defrosted it and let it sit until today.
So I had a bad battery. Swapped it out and she started right up... and then proceeding to plume white smoke out of the tailpipe. It isn't a LOT of white smoke, like it was last time when I overheated the engine and blew the head gasket, but it's definitely enough white smoke to concern me.
I checked the oil. It looks slightly frothy, but the coolant seems to be clear.
I'm going to do a compression test tomorrow or this weekend, whenever I get time, but I'm leaning on the side of blown headgasket or cracked block.
Can the coolant freezing blow a headgasket? The coolant was changed/flushed in august.
If the coolant froze and cracked a block wouldn't it render compression in a cylinder to 0psi? Therefore the car wouldn't start right?
Well looks like things work in mysterious ways. If the block is somehow cracked I have a 4g63 in the barn... Maybe I WILL go through with the swap this summer...
