Just curious. I mean if one read really low then I think it might be a good indication that the thing is dieing, but with both of them reading the same exact value it has me confused. Currently I am testing out an Eprom chip for a guy that is trying to create them for 2g's, and the chip is supposed to have injector compensation for my 625's, stutter box, no lift to shift etc. All of the rev limiters dont work, I found that out the hard way by testing the NLTS and wound up finding my revs hitting 9k before I let off (I know I know, I nearly shit myself as well). The car never has idled right nor ran right with the chip in, always having hiccups every half second or so, even while driving. Originally before the 9k rev that I did the thing would read around .92-.90v on the o2 bank 1, then when I got home after nearly shitting myself I noticed the bank was reading .02 and staying there. I decided to log o2 bank 2 and it too was just sitting there. My idle is varying from 750-920, back and forth all over, and the car sounds horrible at idle. When I first got back from testing it out it was idling between 750 and 680 and sounded horrible. My STFT is at around 0-5% and my LTFT just sits there, although when I got back from driving around it was around 3% and just sitting there. Just curious what you guys think.
At this point feel free to throw out ANY idea, even off the wall ones, as the chip I'm using is just a beta chip that I was testing out, and I have removed my Safc in preparation for my DSMlink arriving friday, so I've been all over the ECU's harness wires. I had pulled the negative cable before hand so I dont believe there're any shorts or whatnot anywhere, and I believe all connections are secure, but again feel free to throw out any ideas, even ones you feel may be off the wall, because as of right now I'm using untested equipment.
