I have a glowshift wideband installed that was working flawlessly until I did some upgrades. I've since pulled the head and went through all of the gaskets and belts, replaced the turbo, ported a bunch of stuff and added a 2.5" DP.
The car is just now coming back to life with FIC 750s, 190lph walbro, aeromotive FPR set (vac off) at 43 psi and a braided line from the (new) fuel filter to rail. I'm getting fuel, the car runs relatively smooth for being completely untuned. It smells a little rich even, but will flash 20 afr on the gauge nearly the entire time it is powered on.
Presuming there are no vac leaks, no exhaust leaks and no fuel leaks. I know when in a DSM's off throttle fuel cut, my gauge will peg lean and flash 20. It is doing this all the time, but I don't see any running issues aside from being un-tuned (working on it).
I cruised the car just a little, not getting crazy with it, and saw the gauge jump from 20+ to a metered 10-12afr, then back up to 20 after slamming back to an unmetered -10 afr.
Does this sound like the gauge is displaying the only thing it knows when reading an AFR too fat for it's capability? I am not trusting it's 20+ flashing because the car would run like crap if it were that lean all the time.
