OK I have a 95 automatic GS-T, FWD Turbo. I blew up my stock motor. So I put in a 1G Race motor with JE Pistons, crower rods, etc. along with a 1G intake and 1G throttle body. Trying to get the best out of both Gen's. Everything swapped great as there is plenty of helpful digrams online from RRE and Magnus, but nobody ever mentions the swap into an automatic 2G which I have. So obviously you know my car originally had a 7 bolt motor and a 6 bolt was put in. The only problem I am encountering is the flexplate. Does anybody out there have aftermarket flexplates for the automatic? The 4 bolts do not line up perfectly to the torque converter. If you drill out the holes on the flexplate a little further to the edge it will fit, but does not seem safe. It is only a few mm's off. Has anyone out there put a 1G 6 bolt motor into an automatic 2G? Please help.
