21 - 40 of 92 Posts
My bad, I forgot it's a private forum.
Here ya go:
A few pictures of my newest modification to my Talon.
The correct way to remove power steering from a car besides replacement with a manual rack. This is known as a de-powered power steering rack.... Enjoy.
Looks normal enough, right?
What's this? Are these fabricated plugs? Why, yes they are.
See anything missing in this picture?
Oh yeah, that's right. These are supposed to be there....
"What is this I'm looking at", you ask?
When you remove the belt that drives the power steering pump, you are removing the "assist" to the system. Therefore, the pump is no longer creating the pressure needed to assist with the steering direction. Aside from common belief, the resistence you feel after removing the belt is actually the fluid being forcefully redirected through the lines and partially reverse bias towards the pump. So what has been believed as "removing power steering" is a matter of looping the pressure and return lines together, creating a closed fluid circuit. The "feel" isn't as stiff as before the "removal" and is tolerable by some.
These pictures are of a "de-powered" steering rack. I prefer this method as opposed to replacing the rack with a "unicorn" manual rack because I still maintain the quicker turn-to-turn ratio which gives a more responsive feel when driving. "Isn't it going to be hard to drive at low speeds"? If you guys can deal with the feel of just the removal of the belt, then, this time, you are in for a treat...
Here ya go:
No problem, thank you for posting it up. I actually joined the forum to see if he had anymore info of how it was done, but he only eluded to there being a few more things that were needed other than whats listed by Flyin' Miata. I am seriously considering this as something to do, but since my Talon is my daily, I want to make sure I can do it. Thanks again.
So all you do is plug the stock lines. Then cut off those 2 things that run fluid across the rack or what ever and weld them shut? He didn't really explain anything..
I've done it in my Expo van, (same thing). I love it, changing lanes has to be the funnest thing in the world right now. I tore the rack apart and hack sawed the seal off the rack. I also go new inner and outer tie rods and boots. I LOVE it....until i got my dui a few days ago
Even my little 120lb girl can drive it because shes the one driving me around now, she has trouble doing 90* turns and in parking lots. overall road feel is 1000x better. I always thought that the stock power steering was way to sensitive. It took me about 2 days, and an alignment later. I would put it at 7 on a one to ten, ten being the hardest.
I'm gonna do this on my beater car. Since it's an early 90's mercury it should be nearly the same rack as what's in the miatas. Would be cool to see done on a 2g and a writeup on how it feels to drive afterwards.
Yeah I will be doing this also when I pull the engine.
VFAQ would be nice.
I did this on my rx7 per flyin miata as its the same rack almost and it came out great...however there is another write up that goes further than flyin miata. Since I found out my rack is leaking on my 1g I will be yanking it in two weeks to depower it...if someone doesn't do it before then I will do a vfaq for everyone
21 - 40 of 92 Posts
