Hello,
I bought a 99 Eclipse GSX recently, and now have a problem with high beam fuse. The high beam indicator on the instrument cluster was on when the headlights were off, I checked the "hi beam" 10A fuse and found it and everything around it in the fuse box melted and burned. I put a new fuse, the high beam indicator turned off, and everything looked normal, but when I checked the fuse a week later, it melted again!
That's how it looks:
It's strange it didn't blow, just melted. Probably the amperage was still below the limit, but something is definitely wrong. I've just checked the current and it constantly shows 7.3A when the headlights are off (and engine not running). I guess it's too much, and if this high current constantly flows through the fuse, it may get hot and melt.
Can someone tell me what current is normally supposed to be there, and what could be wrong in my car? Seems like the headlights I have are the halo ones, which AFAIK require special connection, and probably the previous owner screwed something up.
Any clues, what to look at to fix the problem? I'm afraid the car may go on fire next time.
Thanks.
PS. I did search the forum, but haven't found an answer yet. There was some mentioning of the non-standard headlights polarity in Eclipse, but not enough details. Could that be related?
Thanks.
