1 - 9 of 9 Posts
Eclipse_GS-T4
Does anyone else out there have the problem when you upgrade to a 16g turbo on a 99' GSX and when you reach about 4500 or 5000 rpm that it cuts in and out vigerously. like the engine is kicking or something? I am thinking it is because i have no boost controller hooked up to override factory setting? i am putting in a APEX i boost controller today after school (only a junior in high) and then im putting on my Greddy BOV and then should things work right? because im wanting my other 3000 rpms!
rewire fuel pump and turn boost down as low as it will go. Do you have any intake or exhaust mods? And please tell me you have a boost gauge to use with that boost controller. Be careful man and good luck.
Your list of mods from your profile:
Big 16G, Apex i TT, Ractive exaust, 2 Eclipse 12'', 2 800 watt amps (audiobahn), Eclipse Headunit (not factory), B&M short shifter, Accel Spark wires, and plugs, Injen Trubo Intake, Greddy BOV, 750cc Injectors, APiller Gauges, Custom Red interior.
What are you controlling your fuel with? :dunno:
Moved to Help Tech.
Yes i have a Inken Intake, and just a ractive muffler soon to upgrade to a catback, and i have a bigger fuel pump that i bought the same time as the 16G was purchased.
what kind of gas mileage are you getting?
1 - 9 of 9 Posts
