Ok so about two weeks ago I noticed the Talon starting to misfire after hot starts. By this I mean that the car ran perfectly when started cold, but if I shut it off and restarted it there was a constant misfire. This evolved into a misfire under boost when the car was hot and eventually the car started misfiring all the time. Replaced plugs, wires, and coil and got back to the original situation, car runs fine cold, once hot or after hot starts the car misfires. Any idea what my problem might be? I'm thinking stuck injector or ignition module, but I really have no clue and I am tired of playing with this thing, need to determine cause soon.
Things to note, all plugs except cylinder two have high speed glazing (normal for this car), plug two seemed slightly rich with little to no white on the plug, compression is low but consistent across the board as it has been since I bought the car.
