I did not know what forum to put this in, hopefully I won't piss anyone off by putting this post here.
I have a 1999 GSX 28,xxx miles, and it sounds like the lifters tick sometimes. Not all the time, and it is NOT the injectors ticking. It is louder and it does not always happen. I am pretty sure it is lifter tick, but I thought it was only something that happened to older first gen cars. I have an appointment for the 20th of this month. I guess I'll know then what the problem is, but they listed the work to be done as "replace cam followers" So that means lifters right? It is under warranty so it's not big deal (No $$ out of my pocket), but has anyone ever heard of a 1999 doing this? If it matters at all, I run Castrol synthetic 10/40. I live in California, it doen't JUST happen when it gets hot outside either, it happens whenever it feel like it. It will go away if I rev the engine a little, but then it will come back within a couple seconds. I have only the factory oil pressure guage, but it always reads in the "Normal" range, just above the first line at idle. Hopefully someone will have some imput as to what this may be, or a list of other things I should check. thanks everyone
