Hey all,
I'm new to this DSM thing and need a bit of help.
I got a hold of a 91 Talon about a month ago and can't seem to get it running right. For the most part it will rev up fine in neutral, but when I hit the throttle seems to hesitate for a split second, and then rev. While driving things are much worse. At different rpms and in all gears the car will sputter and lose all power. I can give it more throttle while sputter and it seems to get passed the issue and take off, but when rpms drop it all starts over. If I ease into the throttle the problem doesn't seem to be as bad. With all of the research that I have done I can't seem to solve this issue.
Here is a list of modifications...
91 Talon TSI
NGK plugs and wires
T3/T4 turbo
Tial 38mm wastegate
HKS bov
Megan exhaust
GM MAF is installed but not hooked up. (using stock)
Safc II
Wideband
I'm not sure if my safc is set right.
I'm lost here so if anyone could help me out it would be greatly appreciated.
If you need to know anything more I'll answer anything that I have knowledge of.
Thank you everybody for your time.
91 Talon TSI
NGK plugs and wires
T3/T4 turbo
Tial 38mm wastegate
HKS bov
Megan exhaust
Safc II
Wideband
