Adjustable Constant Intake Air Temperature (Long)
Wouldn't be great if you can hold your IAT sensor fixed at some voltage/temperature? I'm not talking about the old IAT mod where you would solder a 10k potentiometer in series with the thermistor.
My method is to splice the IAT wire (#8), leave the MAF end opened with the thermistor and feed the ecu end with a 10k pot and 5v source.
By using a 10k pot with 5v source , you could adjust to any constant voltage/temperature the ecu sees. Now probably you're asking what are doing with the thermistor. Nothing, well sort of. Hook up the thermistor with a multimeter/thermocouple and use it to monitor real ambinet temp.
The arguement of doing this is that at idle or part throttle the IAT can get as hot as 140+ deg f. Even with CAI, you would have to wait till WOT to see IAT decreases to the lowest point. Another benefit is that you can delay fuel cut during cold weather. If ambient temp reads 30 deg f (gurantee fc at 15psi), you could adjust the pot to 40 deg f but you have to use SAFC to compensate for that 10 deg f bump.
The drawback is that you have to adjust the pot based on any big change in temperature (night and day temp). Sorry for the long post.
Set,
Set,
