vlaar
Below is the description of the fuel pressure gauge at DSMparts.com that I want to purchase sometime soon. What else will I need exactly to install this gauge? Thanks.
The new Carbon Fiber series is mechanical. All gauges feature a combination of Carbon Fiber Dial, Silver Bezel and Silver Pointer for the ultimate in performance and style. Included are red and green colored light bulb covers for a custom night driving look. 52mm #4712
Discussion starter · #2 ·
Anyone use this kit? I believe B&M sells it for around 30 dollars. Others? Thanks.
The B&M Fuel Pressure Gauge Set allows for accurately measuring fuel pressure. Proper fuel pressure is critical at full throttle to prevent lean conditions. Recommended for use with CommandFlo for a complete, accurate fuel delivery tuning system.
I would be leary of using a mechanical fuel pressure gauge inside the cockpit. If that is what you are going for look into the electrical fp gauges. More money but it is less of a risk of something very bad happening.
I would think that a 52mm gauge would be used on the fuel rail. Plus a $30 fp gauge usually means it is the under hood gauge.
