Battery Size
3 reading
11K views 7 replies 4 participants last post by  RippinGSX
Hey Everybody,
I was wondering does anybody know the exact size of a replacement 1st gen battery, Like the actual inches(lxwxh) I think i heard it is like a group 24 i think. The reson i ask is because i am into car audio alot and i want to get a everstart maxx from walmart with 900 cca's, i think it will fit but i don't know for sure. I would check for myself but i don't have my car with me right now.Also if you are wondering why i just won't move the battery to the back I don't have the funds to do it properly now. By the way the batery is going in a 1991 Eclipse GSX,thanks
cool,thanks gonzo, i don't know where i got group 24 from oh well
cool,thanks rippin,how many cca's is the d34/78 is it 780cca? Thanks again
watch the clearance at the top!
When installing bigger batteries in a 1G, you can remove the plastic battery box to get more room.
But be very careful of the top positive terminal -- depending on the battery terminal you use, it might hit the hood and short out.
Batteries must also be firmly bolted down. If you can't use the stock bracket, make a new one.
Also be careful of the battery hold down screw on the fender side of the bracket --it strips very easily.
Exide Orbital fits in 1Gs and has better specs than Optima red-top. The yellow-top has less cranking amps but can withstand deeper discharges with minimal damage.
Cheers,
Mark
PhillyDSM.com
Re: watch the clearance at the top!
Cheers,
Mark
PhillyDSM.com
I never had mine firmly bolted down under the hood. Where is it gonna go? It's an Optima which can take over 18 times the vibration load of a regular lead acid battery and it cannot spill period because it's sealed. Doesn't matter for me anymore anyway because I now have an Optima D31T in the back and no battery in the front at all.
