1 - 16 of 16 Posts
1Fast96RS
what's teh best place/[rice youve guys found for this setup, looking at getting some on friday, also what camber kit is recommended? and tire size if 17's 215/45? any tire recommendations?
I'd get them nowhere other than RRE, though you'll have to take a number from the sound of it.
I live in IL, but if/when I get these, I'd drive my car to CA and make a week of getting this and other suspension stuff done at RRE.
Discussion starter · #3 ·
i can never find them on there website but they are one of the most reputable sources i may have to go there and call em up and check the stauts of the parts.
thanks
Discussion starter · #5 ·
another question teh JIC's or the Tein's Flex?
whats better, no auotxing here just want an awesome handling car, ot keep up with the big dogs in the twists.
The JIC FLT-A2 are a higher trim model than the Tein Flex units. So based on those two models I would go with the JICS.
igs said:
How are they a higher trim model?
1) They're not even the same model.
2) They're not even made by the same company.
What I meant by that is the FLT-A2 are the highest grade models that JIC makes. Basically their top of the line model. The tein Flex units are a lower model, more of an entry level coilover. If you are going for a hardcore race setup than the FLT-A2's are the ones. If you want something with a little more streetability the Tein Flex will do the job.
Ok. But what can the FLT-A2s do that the FLEXs can't? The FLEXs even have a better spring rate.
Alot of it is with the construction of the struts and the damping cabalilites. All the Teins have 16 levels of dampening capabilities. But the strut cartridges used are not the same on all models. For example the tein basic and Flex use the same strut cartridge, but my Tein Type HA's use a totallly different higher end strut cartridge. The higher end units tend to have more dense thus more responsive gases. In the case of the FLT-A2's they utilize nitrogen, much like Ohlins does. So the piston speed and dampening force is increased and thus greater confidence, predictability can be felt with high-end units. In addition to that the cartridges on the FLT-A2's are inverted, upside down if you will. This gives you almost unlimited adjustablility. To add to that, the FLT-A2's have adjustable mounting brackets. So you can adjust the height of the spring perch and also can adjust the height of the lower mounting bracket. The later being a very huge benifit. This can permit the spring and dampening force to be at the optimum and then adjust the height of the lower bracket. Which is Excellent for corner balancing. were as with the flex you can only adjust the height of the spring perch. Which require you to find a happy medium when corner balancing these. You have to sacrifice a little rebound, spring rate, ride height to achieve the same goal. Now if you go with a Higher Tein unit, like mine the Type HA, the strut cartridges used have great dampening capability and quicker shock rebound. They do not have adjustable lower mounts, but make up for it with helper springs to allow you to get it all where you need it and have the helper springs keep it all in place.
So basically, you need the top of the line Tein Units to compete with the top of the line JIC's
The ones for the 2Gs are not inverted. But the monotube design is an advantage.
The FLEXs have adjustable brackets as well.
This is incorrect.
This is incorrect.
My expertise is in the 1G realm. I apologize for the incorrect info on the lower mounting bracket. The guys that I had seen, his lower brackets were not adjustable. You would think a guy and an SCCA event would know what he is running, maybe he was mistaken on his model being "Flex" units. My bad on that one. So in the case of 2G's the Flex's may be a good alternative. But in the case of the 1G, all serious enthuisist or die hards that I know, if given the choice between the FLT-A2 and the Flex. The FLT-A2's win hands down.
He must have been mistaken. All FLEXs have adjustable lower brackets. So even for 1Gs the FLT-A2s have no real advantage. The FLEXs will save you a lot more $$$ too.
He was driving a 96 GSX, and like I said 2G's are not my thing. So I did not question him. Anddont get me wrong I was not trying to say that the JICs are the Holy Grail or anything. I Personally running Tein's myself. Although mine are Type HA, which are one trim below the full blown N1 competiton sets. For most folks in "my" circle the Flex's are considered "Entry Level". Thats all.
where all on the same team here. Just passing my opinion and knowledge. Thats all.
Jose
ArcticTsi
1 - 16 of 16 Posts
