I installed a ported big 16g the other day. I tried brake torqueing quickly to see how much boost I could buiild off the line, and i bogged. Anyone have any suggestions, should I brake torque longer?
Yep that was the problem.98TalonTSi said:I guess I'll try another leak down test. Is that what your problem was a boost leak?
Yes its a big job. About the same amount of work as a new clutch in a m/t dsm. Add in the end clutches, shift kit(wich is also alot of work), good fluid, and a trans cooler and you will be set. I just put in a new filter/ B&M synthetic trick shift, and it made a difference in my car. I'm still trying to get end clutches from charles, and will proably get a shift kit some time over the winter.98TalonTSi said:Is changing the torque converter a huge job? And can I leave my tranny stock, and just change the clutches and add a shift kit, and tranny cooler?
I also have the same problem as you. I'm hitting full boost at about 3,900 to 4,000! What did you do to the AVCR to make it spool faster?98TalonTSi said:I'm convinced my AVC-R is messing with the turbo too. I'm going to sell it, but the other night, I was messing with it and all of a sudden, I'm able to build 5 psi off the line, and I hit full spool at 3400 instead of at almost 4000.
