Alright so i was planning on buying a cai for my nt eclipse and a lot of people told me i should get a bypass valve...could anybody tell me exactly how these work, and where at do you put them? Thanks
My thoughts exactly...jcarothers said:I've even heard of some of the early ones breaking up and getting sucked up themselves..
yea, but being the type of person that I am(lazy), I don't think I'm gonna want to pop open the hood of my car and remove part of my intake in the rainEagle 5 said:msot CAI has 2 sections to them, and upper and lower section. so if oyu wanted you can put the CAI on and if its goign to rain and you are afriad of the filter going into water then remove the lower section and attach the filter to the upper section, problem solved.... i doubt oyu would wnt to do this a lot but hey, it works
just dont try and drive across rivers and streams
Most of the time the bypass valve breaks up and gets sucked in, it was installed on an application isn't wasn't supposed to (IE: AEM bypass valve on Ractive intake.)jcarothers said:I've even heard of some of the early ones breaking up and getting sucked up themselves..
i really see no reason why a different model of intake would be cause for the 'filter' of the BPV to be more likely to be sucked into the engine as long as its installed properly...dsmfan95 said:
AMEN BRUTHA! hahaha 'see kids? the truth is much easier to see when you follow the $$' -wiley millerspdjnky said:I've personally seen this happen on my friends car at the track. The bypass valve exploded, butthankfully nothing got sucked into the engine. It has nothing to do with what type on intake, the bypass valve is just another way for them to make more $$.
