Coolant temp needle goes up then down while running.
1K views 6 replies 6 participants last post by  greenstreak
I have a 2G non turbo. When I am driving it it is almost all of the time running at normal temperature when suddenly the coolant temperature needle goes up to about 3/4 or a bit over that and then comes back down to normal temp. The whole process lasts about 4 or 5 seconds. I have noticed that it happens with the air conditioner on or off but if it is very hot outside it will do it with less frequency than if it is not hot outside. I live in Puerto Rico so when I mean hot I mean sunny and around 90F and not hot would be at night which is maybe 75F. What could be causing this problem? Both fans are working.
I want to fix this before it causes other problems
Thanks
Louis
