So i search and i came across quite a few posts where someone said they didn't use the special tools to set the t-belts tension correctly. im doing a 6-bolt swap so i can't use the trensioner tool (long threaded rod to get tension off) and don't have the tool that you insert into the tensioner pully.
i do have a vice, and so far i have removed the belt, replaced the balance shaft belt already, alinged the marks and made sure the balance shafts are in phase. Then i removed the auto-tensioner and compressed it and inserted an allen wrench to keep it compressed. i then bolted it back on the engine.
Now what do i do? the tensioner pullie has the two holes alinged to its left and the center bolt is finger tight. the belt is on but how do i apply the correct tenstion?
i have the two drill bits to check for the gap. Thanks for any advice! if im really dumb and it something simple then so be it, whats the simple step!
